2016-07-17 11:34 PM
Hello there,
I have a question regarding TSC101 amplifier. Will it work if current will flow through the sense resistor in a reverse direction? I was wondering either it is possible to use it like this:https://dl.dropboxusercontent.com/u/14154631/Zrzut%20ekranu%202016-07-18%2008.32.00.png
Instead of a classic high side sensing configuration like in the datasheet. I would appreciate all help.2016-09-15 9:28 AM
2016-09-16 12:49 AM
Actually, the TSC101 is a mono directional amplifier, so it won't give any current indication if current flows in the opposite direction (output voltage of TSC101 is clamped to zero in this case).Best regards,Anthony BoimondWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
