2016-06-28 7:01 AM
Hi To all,
I have a problem to new design, based to de datasheet of the TDA-7498-L, Every time when I put in STBY off, the Intensity increase, and the device is burn. I compare two, diagrams and I doesn�t found possible the fail. Attached I send my Schematic Any suggestion..? Many Thanks In advance #tda-7498 #audio-amplifiers2016-06-28 7:11 PM
2016-06-28 10:41 PM
Hi, Zhao.
Thanks a lot for your answer. Sure, i send to you the dessign to my pcb, no problem. The problem in my design, is When connect the power supply to my pcb, works fine, no problem, the quiescense instensity is not more than 5 mA, but when in put the system in standby off, increase the instensity, and the chip is destroy.. I doesn´t undesrtand wher is the problem.. ________________ Attachments : tda7498-pcb.bmp : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006Ht23&d=%2Fa%2F0X0000000aJ5%2FhdGpVI4JFA7Va97S2MQgY_xvAD7uRZCaaHd6acTZdaQ&asPdf=false2016-06-29 11:25 PM
