Analog and audio
Forum board changes
ST audio IC with SPI
for reading micro sd audio data (SPI), I need to choose a Audio IC with Vol +, Vol-, next and pre funtion. Anyone How has expereince with that?Thank you
ABous.2 by Associate
  • 668 Views
May we use TSA4871 in single singled mode?
On a existing Electronic board, the following schematic is implemented:May I use it in single end mode with a serial capacitor between VS+ (or VS-) and the load connected to GND?May the other output VS- (or VS+) stay unconnected?What is the bias volt...
SBour.2 by Associate
  • 678 Views
TS3022 - Clamp overvoltage in ESD input diodes ?
Good morning,I am working on a basic test bench application and considering the TS3022, unfortunately the inverting input voltage may go beyond the VCC rail (which I cannot avoid due to pre-existing architecture).I am wondering:is there integrated ES...
Gleme.1 by Associate
  • 809 Views
Real-time clock M41T62 per day leave for 6 minutes henceforth
Real-time clock M41T62 per day leave for 6 minutes henceforth. I found out that the quartz frequency is about 32.9 kHz. Program calibration does not reduce this inaccuracy. Do I have a defective chip or I don’t understand something?
AGari by Associate II
  • 1594 Views
GM68020H datasheet need
Hello,i want to use GM68020H to research ,but i can't find out its detail data sheet ,can you send one to me?My email :2664822931@qq.comThank you very much!
Djie.1 by Associate II
  • 2751 Views
STPM34 Line and Neutral connection
I have used STPM34 In my design. I am measuring voltage and current of single phase supply. Line is connected Pin number 9 of STPM34 and neutral is connected with circuit ground via ferrite bead. check R23 in schematic. I have attached schematicMy...
RKara.1 by Associate
  • 755 Views
