Analog and audio
Forum board changes
Resolved! Does ST provide SPICE models for comparators?
Just wondering if ST provides a SPICE library for the TS985 comparator? I haven't used many parts from ST and could help with any advice. My goal would be to simulate the comparator within LTSpice.Thanks,Alan
alano by Associate
  • 1908 Views
Resolved! About output waveform problem of CS42L51
Hi,This is my previous question(link).I'm implementing 24bit, 44.1kHz audio out code using STM32H7B3-discovery.In previous question, i set SAI(I2S format) buffer like below.I set SAI_A block to output.And, this is my SAI_A setting.​​I set tx buffer t...
0693W00000LyztVQAR.png 0693W00000LyzuiQAB.png 0693W00000LyzusQAB.png 0693W00000Lyzv2QAB.png
Younjun by Associate III
  • 2516 Views
Resolved! Can single TDA7293 handle 100W RMS with 4 ohms?
Hello,I am planning to build amplifier based on single TDA7293 SoC, in class G (as described in technical note). I have 2 voltages, +22/-22 and +45/-45V. The speaker has 4 ohms. Can TDA7293 handle the 100W RMS power, or it is too much for single chip...
MMarg.1 by Associate
  • 3553 Views
