Analog and audio
Forum board changes
STA540 ?
Good afternoon....I am looking into using an STA540 in a power amp design for a single supply 4 ohm speaker. Other than the datasheet there seems to be no reference design material on how to use this chip. I have found Sparkfun has a reference desi...
SWenn.1 by Senior III
  • 666 Views
Request technical information for Reference : TSB7192AIST
Hello, I send you this message to ask you to provide me, if possible, the information below- RoHS II Status : Yes, with exemption, No- J-STD-020 Moisture Sensitivity Level Rating (MSL)- Termination Plating Finish- Quantity of parts in a packaging ( R...
AIcha.1 by Associate
  • 982 Views
STuW81300 I designed a device with STuW81300. PLL locked. I received output power like in the datasheet. Okay. But when I measured the output signal, I saw a lot of spurs. I don't know how to improve my signal. Do you give me support about this spur?
STuW81300I designed a device with STuW81300. PLL locked. I received output power like in the datasheet. Okay. But when I measured the output signal, I saw a lot of spurs. I don't know how to improve my signal. Do you give me support about this spur? ...
STuW81300 RF Output power is lower than expected.
I am using the STuW81300 as LO generator to generate 12GHz LO. Although I am able to get the frequency out correctly and the PLL is also locking the output power of the signal us at -39dBm (probing) where ideally it should be giving close to -4dBm. T...
JJose.6 by Associate
  • 987 Views
