Analog and audio
Forum board changes
hi im working on FDA903D AEK AUD D903V1 autodevkit, im trying to send information from an NXP MPCU5748G microcontroller through I2C AND I2S.
i have set enables 1,2,3 and 4 as 1100 which is address 2 , but for some reason the speaker is not open and voltage is not passing through it which means i cant move on and give orders through i2c registers, can you please explain what the reason mig...
aturk.2 by Associate II
  • 861 Views
Thermal Model for TDA7803A
Needed Detailed Thermal Model for TDA7803A which includes Die, Solder balls etc., and their material properties for thermal simulation
How To call a function in c++
Hi, I recovered a program and I would like to use but I do not understand very well. Could you give me some info. Thank you for your helps Regards
DYann.1 by Senior II
  • 982 Views
Hi Team, we have two products with the TS4984 BTL amplifier designed in. We would like to mix the signals at the output stage into a single 8 Ohm speaker.
Is it possible to operate 2 x TS4984 amplifier as a PBTL only using the Left channel from each product. (Both products share the same power domain)We have prototyped a small interface consisting of 4 x 100uF non-polarized capacitors to mix the differ...
DHadd.1 by Associate II
  • 1323 Views
SGTL 5000
Hello, I would like to know how to communicate a CODEC SGTL 5000 with STM32 ? Do you know where I can find the the library (.C and .h) of this component ? Thank you for your helps. Regards
  • 1561 Views
