Analog and audio
Forum board changes
Is the TS954 SPICE model accurate
I matched figure 3 in the datasheet with a level3a spice model and I can get a good match. When I used your provided model the crossover is VERY low. Also I don't understant how the datasheet has 80dB of DC gain, but the model and open loop respons...
ktomp.1 by Associate
  • 1632 Views
Resolved! Audio noob question
Preparing for some audio related project....If I understand correctly, I2S can transmit and receive simultaneously like SPI.Is this mode used practically? Are there codecs that can simultaneously transmit via I2S (generate sound) and receive digitize...
Pavel A. by Super User
  • 7631 Views
  • 13 replies
