2016-10-12 7:50 PM
My SW read audio with PCM format from STA321MPL. The same time it read PDM format from Digital Microphone. Both are set with 16 Khz sample rate. It always has
5 samples delay in audio signal from STA321MPL compare to audio signal from digital Mic. All are set the same source clock. I have reviewed my code but could not find anywhere lead to this delay.2016-10-17 7:28 PM
hi Le_son,
the conversion from PDM to PCM is similar with AD conversion , and normally group delay will be introduced in processing channel .
so it's normally behavior for audio processor .
Thanks
YT
