2026-01-12 4:39 AM
As mentioned in the AN2606 document for STM32F412VGTx MCU(Custom chip), I am using USART2 (PD6/PD5) for UART bootloader using STM32CubeProgrammer. But I am getting an error message as attached. Help me to resolve this issue.
2026-01-12 4:43 AM
Welcome to the forum.
@shanmukhi wrote:STM32F412VGTx MCU (Custom chip)
STM32F412VGTx is not a custom chip.
Did you mean STM32F412VGTx on a custom board ?
If so, you need to give details of that board:
How to write your question to maximize your chances to find a solution
@shanmukhi wrote:
So have you checked those things?
2026-01-12 5:54 AM
One of these is likely wrong:
2026-01-12 6:17 AM
@Andrew Neil wrote:Did you mean STM32F412VGTx on a custom board ?
If so, is it a known-good commercial product, or your own design?
Have you checked the design against Application note AN4488, "Getting started with STM32F4xxxx MCU hardware development" ?
Has this board ever worked ?
2026-01-12 2:30 PM
Any signals on PA10 or PB11 that might be recognized as initial contact?
You only get one-shot at reset to make a connection, if that fails you must with BOOT=HIGH to try again.
Present schematic for what you've implemented, saves everyone have to guess at causes..
