2024-07-08 4:32 AM - last edited on 2024-07-08 6:43 AM by Peter BENSCH
So i installed the st-link utility from my.st.com and did all the installation but when i run it, it tells me there are some .dll files missing. Specifically, these are the errors; 1st error; "The code execution cannot proceed because mfc140.dll was not found. Reinstalling the program may fix this problem" and the 2nd error is; "The code execution cannot proceed because MSVCP140.dll was not found. Reinstalling the program may fix this problem." . So i did exactly that, uninstalled the st-link utility and installed it again but still same problem. Does anyone have the same problem and how, if you fixed it, did you do it?
2024-07-08 6:41 AM
Welcome @null_byte, to the community!
the ST-LINK Utility is deprecated and already on NRND (Not Recommenden for New Design) anymore. Please use the STM32CubeProg instead.
Hope that helps?
/Peter
2024-07-08 6:41 AM
Hope that helps?
/Peter
