2019-11-16 6:29 PM
2019-11-18 3:56 PM
Hi Oliver,
I found another question similar to mine with a lead to the solution. The solution was to uninstall all of my JDKk and Java 8 update 231, then install the cube programmer, then reinstall the Java update. Since then all is well.
Thanks for your response.
Dan
2019-11-18 5:24 AM
On which OS are you installing CubePro ?
Did you refer to UM2237 for installation ?
Olivier
2019-11-18 3:56 PM
Hi Oliver,
Dan
