STM32CubeProgrammer (MCUs)
Ask questions on STM32CubeProgrammer and find answers on device detection, connection failure, programming issues, and more.
Resolved! STM32CubeProgrammer v2.22 released
Resolved! SFI Step-by-step on STM32 boards with STM32HSM-V2AE
Hi,I have a STM32HSM-V2AE and I tried to follow de "SFI Step-by-step on STM32 boards". In the part of "HSM programming" I connect the STM32HSM-V2AE to the computer with the smart card reader ACS ACR39U-UF but I have the following error:Error: HSM ini...
mikel-m by Associate III
  • 4503 Views
Resolved! STM32H563ZI Flash Bank Swap
Hello all, I am currently developing on the STM32H563ZI and encountered an issue where, when swapping to Bank 2 to erase/write flash, it simultaneously erases the same address in Bank 1. Here are the steps I followed: Swapped to Bank 2.Used STM Progr...
IanLin by Associate
  • 5119 Views
  • 5 kudos
Difference between device memory and file
Hey everyone,I was writing a 'How-To' for flashing an STM32F04 while I stumbled upon this phenomeon.After program&verify I read back the device memory and compared it to the file I downloaded.I then get the message 'Warning: difference found at 0x800...
xSammy by Associate
  • 2377 Views
Resolved! Enabling RDP when TrustZone is active
Hi,I am conducting tests with the HSM and SFI. I have tried the use case of attempting to install an SFI with an HSM that uses other keys. Obviously, I couldn't do it, but now I cannot connect the microcontroller in "normal" mode. If I connect it in ...
  • 1468 Views
Shutting down... Exit.
 STMicroelectronics ST-LINK GDB server. Version 7.7.0Copyright (c) 2024, STMicroelectronics. All rights reserved. Starting server with the following options:Persistent Mode : DisabledLogging Level : 1Listen Port Number : 61234Status Refresh Delay : 1...
asda by Associate
  • 2346 Views
