Why can't i chose the sw4stm32 as the toolchain when using cubemx to generate code? I'm using STM32H723ZGT. Thank you for your kindness.
LeiZhenYU
Associate
1 ACCEPTED SOLUTION
Accepted Solutions
MM..1
Chief III
SW4STM32
NRND  <<<<<<<<<<<<<<<<Why yes ?
3 REPLIES 3
MM..1
Chief III
SW4STM32
Andrew Neil
Super User
As @MM..1​ says - Presumably because, like TrueSTUDIO, it's no longer supported?
TDK
Super User
Since SW4STM32 itself is no longer supported, it's not being supported as a code generation option on newer chips within STM32CubeMX.
