TouchGFX and X-CUBE-AI co-existence
ERROR
Senior
I have a project with TouchGFX based on STM32N6570-DK.
In STM32CubeMX, once I tried to add X-CUBE-AI, I got stuck, and the error is appeared as shown below.
What does it mean?
Once I removed the TouchGFX Graphic Application, the X-CUBE-AI can be enabled, but the generator removed MX_TouchGFX_Init() etc.
Are there any side effects, if I restore the TouchGFX code manually?
And I’m curious — why does this limitation exist?
Regards!
1 ACCEPTED SOLUTION
Accepted Solutions
Souhaib MAZHOUD
Hello @ERROR
Actually, X-Cube-AI and touchGFX cannot be used simultaneously. The explanation has already been discussed in this thread.
KR,
Souhaib
2 REPLIES 2
Souhaib MAZHOUD
Hello @ERROR
KR,
Souhaib
ERROR
Senior
Hi @Souhaib MAZHOUD ,
thank you!
