STM32F1, CubeMX and FreeRTOS: undefined reference to pxCurrentTCB and vTaskSwitchContext
Posted on March 29, 2016 at 19:33
I'm trying to build an ''empty'' project generated by CubeMX using FreeRTOS and gcc for STM32F103xB.
I'm using the latest CubeMX (4.14.0) and latest HAL (1.3.1).
I've successfully built projects using CubeMX, HAL, gcc that work, I just get errors when I'm trying to use FreeRTOS.
I've added to the include path (-I)
FreeRTOS/Source/CMSIS_RTOS
FreeRTOS/Source/include
FreeRTOS/Source/porteble/GCC/ARM_CM3
I've included in the build:
FreeRTOS/
FreeRTOS/Source
FreeRTOS/Source/portable/GCC/ARM_CM3
FreeRTOS/Source/portable/MemMang/heap_4.c
+ all the other stuff needed to make a CubeMX/HAL project works.
but I get
undefined reference to `pxCurrentTCB'    port.c
undefined reference to `vTaskSwitchContext'    port.c
BTW if anyone from ST is listening it would be nice if you didn't include in the main.c template the cmsis_rtos stuff so one would be free to chose to use FreeRTOS directly or not without having to edit main.c every time.
#stm32f1 #cubemx #freertos #gcc
https://www.borgonovo.net
10 REPLIES 10
Posted on April 12, 2016 at 11:12
[DETAILS]
The assembly and nm, ar section:
https://gcc.gnu.org/wiki/LinkTimeOptimizationFAQ
https://gcc.gnu.org/gcc-4.9/changes.html
