2021-09-20 1:16 PM
Hi everyone. I'm facing some issues trying to open a project created in CubeMX version 4.7.0. Once the project was not created by me, I don't want to migrate it to a newer version (and if I do, which I had already done, I get some errors in some of the interruptions).
Where can I get this version from ST?
Thank you!
2021-09-21 3:04 AM
Hello @ulissestpBR ,
Actually, STM32CubeMX V4.7.0 is not available in the official site, you'll find other version linked here.
What I suggest is, instead of migrating to the newest version, you may select continue to use original firmware that was used at project creation.
In this case, it will be downloaded into your repository as well as the MCU and IPs database.
you'll find linked another post with more explanation, it may help you.
Best regards,
Mouadh.
