STM32CubeMX V5.0.1: error in uwTimclock with STM32G0xx (with Timebase source TIM15, TIM16, TIM17)
wuio
Associate II
If, as the basis of time, I use a different timer than the systick in the hal_timebase_tim file in the ruler
 uwTimclock = HAL_RCC_GetPCLK2Freq ();
there is an error. Should
 uwTimclock = HAL_RCC_GetPCLK1Freq ();
1 ACCEPTED SOLUTION
Accepted Solutions
WBOUG
Senior
Hi @wuio​
Your issue has been transmitted for the dev team.
it will be implemented in the next version of the CubeMX.
Best Regards,
Wael
4 REPLIES 4
Imen.D
Hello @wuio​ ,
Can you please share your ioc file to check this issue.
I cannot reproduce your issue, I checked from my side and I have:
 uwTimclock = HAL_RCC_GetPCLK1Freq();
Kind Regards,
Imen
When your question is answered, please close this topic by clicking "Accept as Solution".
Thanks
Imen
wuio
Associate II
It depends on which timer you choose as the basis of the system time. I chose tim17 but when I chose tim 6 it was ok.
Imen.D
Hi @wuio​ ,
You are right, I raised this issue internally to CubeMX team for fix.
Thanks for your contribution.
Kind Regards,
Imen
Thanks
Imen
WBOUG
Senior
Hi @wuio​
Best Regards,
Wael
