2018-08-30 7:17 AM
Hi all,
I'm using STM32CubeMX along with Atollic TrueSTUDIO and experiences a small issue.
Whenever I generate code from CubeMX, the debug configuration of my TrueSTUDIO project gets modified/overwritten to use JTAG as opposed to SWD (which I would like to use).
This means that whenever a generate new code, I need to manually go in and correct the interface.
Do you know if there a solution to this (maybe a CubeMX setting that I'm missing)?
/ Andreas
2018-08-30 8:38 AM
Are you referring to the .launch file? If so, I created one (actually, a few) with a different name that Cube isn't aware of and doesn't mangle.
