2019-07-08 5:08 AM
I'd like to use the user template settings (CubeMX Project -> Project Manager -> Code Generator -> Template Settings) to add own files to the generated project, but unfortunately, it neither shows available templates from the (default) extra_templates folder, nor from any other folder I select. There are definitely ftl files located in the extra_templates folder (see attached screenshot)
Regards,
Daniel
2021-03-23 3:54 AM
I have the same issue.
Did you got a solution?
Best regards
2022-01-26 9:55 AM
I got around this by:
