2021-10-08 4:27 AM
When selecting LSI as output for LSCO pin, and generating code with integrated STM32CubeMX, no output is seen on LSCO pin.
I have to manually add a call to this to see LSI on LSCO pin.
HAL_RCCEx_EnableLSCO(RCC_LSCOSOURCE_LSI);When using MCO pin instead of LSCO pin, the code for source clock selection is generated correctly.
I'm using STM32CubeIDE v1.7.0. and STM32L432KCU MCU.
Thanks and kind regards,
Pedro.
2021-11-29 2:35 AM
Hello @PCast.2 ,
This issue is fixed in the latest release of STM32CubeMX ( version 6.4.0 available on https://www.st.com/en/development-tools/stm32cubemx.html).
Thanks for your contribution.
When your question is answered, please close this topic by choosing Select as Best.
Regards,
Sara.
2021-10-26 6:29 AM
Which STM32CubeMX version are you using?
Best Regards,
Sara
2021-10-26 6:41 AM
Hi Sara,
This is the info about STM32CubeMx version I found in .ioc file:
MxCube.Version=6.3.0
MxDb.Version=DB.6.0.30
ProjectManager.FirmwarePackage=STM32Cube FW_L4 V1.17.0Best regards,
Pedro.
2021-10-26 6:45 AM
Hello again,
Could you please share with us your .ioc file?
Thanks in advance,
Sara.
2021-10-26 6:52 AM
2021-10-27 3:55 AM
Hi @PCast.2 ,
Thanks for your feedback,
You are right, It seems that the STM32CubeMX does not generate the code to enable LSCO output, for now you have to add HAL_RCCEx_EnableLSCO(RCC_LSCOSOURCE_LSI); manually.
Your request have been reported internally, I'll keep you posted with the updates.
Sara.
2021-10-27 4:21 AM
Thank you Sara!
2021-11-29 2:35 AM
Hello @PCast.2 ,
Regards,
Sara.
