2018-12-20 5:56 AM
I downloaded the new CubeMX from the ST site, launched the installer (as the root user) and started the application. It can't start, it hangs at startup. Here are the logs obtained at app startup:
chdir /home/kacper/STM32CubeMX/.
current dir /home/kacper/STM32CubeMX
log4j user configuration file not found: /home/kacper/.stm32cubemx/log4j.properties
Configure log4j with default settings from jar:file:/home/kacper/STM32CubeMX/STM32CubeMX!/log4j/log4j.stm32cubemx.properties
2018-12-20 14:38:09,772 [INFO] MicroXplorer:486 - Detected Java Version = 1.8.0_191
2018-12-20 14:38:09,778 [INFO] ApplicationProperties:181 - Using Application install path: /home/kacper/STM32CubeMX
2018-12-20 14:38:09,790 [INFO] DbMcusXml:68 - Set database path to: /home/kacper/STM32CubeMX//db//mcu/
2018-12-20 14:38:09,796 [INFO] DbBoardsPdsc:54 - Set plugin database path to: /home/kacper/STM32CubeMX//db//plugins/boardmanager/
2018-12-20 14:38:09,796 [INFO] DbMcus:262 - Set plugin images path to: /home/kacper/STM32CubeMX//db//plugins/mcufinder/images/
2018-12-20 14:38:09,796 [INFO] DbBoards:224 - Set plugin images path to: /home/kacper/STM32CubeMX//db//plugins/mcufinder/images/
2018-12-20 14:38:09,798 [INFO] APIGFXSelector:72 - Set database path to: /home/kacper/STM32CubeMX//db//plugins/mcufinder/mcu/
2018-12-20 14:38:09,801 [INFO] DbMcusAds:72 - Set database path to: /home/kacper/.stmcufinder/plugins/mcufinder//mcu/
2018-12-20 14:38:09,802 [INFO] DbMcusDocs:90 - Set database path to: /home/kacper/.stmcufinder/plugins/mcufinder//mcu/
2018-12-20 14:38:09,804 [INFO] DbMcusJson:58 - Set database path to: /home/kacper/.stmcufinder/plugins/mcufinder//mcu/
2018-12-20 14:38:09,805 [INFO] DbBoardsDocs:82 - Set database path to: /home/kacper/.stmcufinder/plugins/mcufinder//mcu/
2018-12-20 14:38:09,805 [INFO] DbBoardsJson:51 - Set database path to: /home/kacper/.stmcufinder/plugins/mcufinder//mcu/
2018-12-20 14:38:10,034 [INFO] CrossReferenceDbSqlite:197 - Set database path to: /home/kacper/.stmcufinder/plugins/mcufinder//mcu/
2018-12-20 14:38:10,155 [INFO] RulesReader:53 - Compatibility file has been processed (127 Rules)
2018-12-20 14:38:10,170 [INFO] STM32CubeMX:31 - Starting STM32CubeMX
2018-12-20 14:38:10,321 [INFO] MainPanel:139 - HeapMemory: 251658240
2018-12-20 14:38:10,410 [INFO] DbMcusXml:68 - Set database path to: /home/kacper/STM32CubeMX//db//mcu/
2018-12-20 14:38:10,410 [INFO] DbBoardsPdsc:54 - Set plugin database path to: /home/kacper/STM32CubeMX//db//plugins/boardmanager/
2018-12-20 14:38:10,411 [INFO] DbMcus:262 - Set plugin images path to: /home/kacper/STM32CubeMX//db//plugins/mcufinder/images/
2018-12-20 14:38:10,411 [INFO] DbBoards:224 - Set plugin images path to: /home/kacper/STM32CubeMX//db//plugins/mcufinder/images/
2018-12-20 14:38:10,411 [INFO] APIGFXSelector:72 - Set database path to: /home/kacper/STM32CubeMX//db//plugins/mcufinder/mcu/
2018-12-20 14:38:10,411 [WARN] DbFile:31 - Overriding database path with different value: /home/kacper/.stmcufinder/plugins/mcufinder/ => /home/kacper/.stmcufinder/plugins/mcufinder
2018-12-20 14:38:10,412 [INFO] DbMcusAds:72 - Set database path to: /home/kacper/.stmcufinder/plugins/mcufinder//mcu/
2018-12-20 14:38:10,412 [WARN] DbFile:31 - Overriding database path with different value: /home/kacper/.stmcufinder/plugins/mcufinder/ => /home/kacper/.stmcufinder/plugins/mcufinder
2018-12-20 14:38:10,412 [INFO] DbMcusDocs:90 - Set database path to: /home/kacper/.stmcufinder/plugins/mcufinder//mcu/
2018-12-20 14:38:10,412 [INFO] DbMcusJson:58 - Set database path to: /home/kacper/.stmcufinder/plugins/mcufinder//mcu/
2018-12-20 14:38:10,413 [WARN] DbFile:31 - Overriding database path with different value: /home/kacper/.stmcufinder/plugins/mcufinder/ => /home/kacper/.stmcufinder/plugins/mcufinder
2018-12-20 14:38:10,413 [INFO] DbBoardsDocs:82 - Set database path to: /home/kacper/.stmcufinder/plugins/mcufinder//mcu/
2018-12-20 14:38:10,413 [INFO] DbBoardsJson:51 - Set database path to: /home/kacper/.stmcufinder/plugins/mcufinder//mcu/
2018-12-20 14:38:10,414 [INFO] CrossReferenceDbSqlite:197 - Set database path to: /home/kacper/.stmcufinder/plugins/mcufinder//mcu/
2018-12-20 14:38:10,425 [INFO] ApplicationProperties:181 - Using Application install path: /home/kacper/STM32CubeMX
2018-12-20 14:38:10,426 [INFO] PluginManage:167 - Search for loadable plugins [exclusion list=]
2018-12-20 14:38:10,427 [INFO] PluginManage:289 - Check plugin power
2018-12-20 14:38:10,443 [INFO] PluginManage:339 - Loaded plugin power (category:power,tabindex:4)
2018-12-20 14:38:10,443 [INFO] PluginManage:289 - Check plugin pinoutconfig
2018-12-20 14:38:10,473 [INFO] PluginManage:339 - Loaded plugin pinoutconfig (category:base,tabindex:0)
2018-12-20 14:38:10,473 [INFO] PluginManage:289 - Check plugin thirdparty
2018-12-20 14:38:10,529 [INFO] ThirdPartyDb:293 - Open Third Party DataBase File (/home/kacper/.stm32cubemx/plugins/thirdparty/db/thirdparties_db.xml) : 33 ms. number of Sw pack : 5
2018-12-20 14:38:10,550 [INFO] PluginManage:339 - Loaded plugin thirdparty (category:base,tabindex:-1)
2018-12-20 14:38:10,551 [INFO] PluginManage:289 - Check plugin pinoutandconfiguration
2018-12-20 14:38:10,558 [INFO] PluginManage:339 - Loaded plugin pinoutandconfiguration (category:base,tabindex:1)
2018-12-20 14:38:10,558 [INFO] PluginManage:289 - Check plugin updater
2018-12-20 14:38:10,575 [INFO] PluginManage:339 - Loaded plugin updater (category:base,tabindex:12)
2018-12-20 14:38:10,576 [INFO] PluginManage:289 - Check plugin ipmanager
2018-12-20 14:38:10,582 [INFO] PluginManage:339 - Loaded plugin ipmanager (category:base,tabindex:5)
2018-12-20 14:38:10,583 [INFO] PluginManage:289 - Check plugin tools
2018-12-20 14:38:10,584 [INFO] PluginManage:339 - Loaded plugin tools (category:base,tabindex:5)
2018-12-20 14:38:10,584 [INFO] PluginManage:289 - Check plugin filemanager
2018-12-20 14:38:10,644 [INFO] PluginManage:339 - Loaded plugin filemanager (category:base,tabindex:10)
2018-12-20 14:38:10,644 [INFO] PluginManage:289 - Check plugin projectmanager
2018-12-20 14:38:10,705 [INFO] PluginManage:339 - Loaded plugin projectmanager (category:projectmanager,tabindex:3)
2018-12-20 14:38:10,705 [INFO] PluginManage:289 - Check plugin clock
2018-12-20 14:38:10,711 [INFO] PluginManage:339 - Loaded plugin clock (category:base,tabindex:2)
2018-12-20 14:38:10,711 [INFO] PluginManage:289 - Check plugin analytics
2018-12-20 14:38:10,839 [INFO] UserProfileFactory:23 - /com/st/library/analyticscore
2018-12-20 14:38:10,841 [INFO] UserProfileFactory:25 - 2022b90f_f4e5_43d2_94e1_693aa975e253
2018-12-20 14:38:10,847 [INFO] AnalyticsPlugin:146 - Accepted Software Licenses: Error : could not load the licence version !
2018-12-20 14:38:10,847 [INFO] AnalyticsPlugin:148 - Accepted CMSIS Pack Licenses:
2018-12-20 14:38:10,847 [INFO] AnalyticsPlugin:150 - Accepted Firmware Licenses:
2018-12-20 14:38:10,847 [INFO] PluginManage:339 - Loaded plugin analytics (category:tool,tabindex:-1)
2018-12-20 14:38:55,539 [ERROR] IntegrityCheckThread:90 - Cannot obtain updater plugin
2018-12-20 14:38:55,540 [INFO] IntegrityCheckThread:94 - End integrity checks thread
2018-12-20 14:38:55,540 [INFO] ThirdPartyDb:263 - Close Third Party DataBase File (/home/kacper/.stm32cubemx/plugins/thirdparty/db/thirdparties_db.xml)
2019-01-01 5:48 AM
Hello did you get it to work? I'm having exactly the same issue here.
cheers
Lukas
2019-01-02 12:20 AM
Hi. I didn't. I have just installed 4.27 version :\
2019-01-02 12:29 AM
There are some solutions in this thread:
https://community.st.com/s/question/0D50X0000A1kmaRSQQ/stm32cubemx-50-under-linux
Deleting thirdparty.jar worked for me.
Olivier
2019-01-02 1:06 AM
Thanks, I just went for running it on Windows /VBox.
2019-03-22 9:10 PM
I can run version 5.01 from Ubuntu 18.04 after doing
sudo apt update
sudo apt install wine64
