2018-05-24 12:10 AM
Extra line Rank 1
and the code is generated the same
ADC3 stopped working
How to fix the problem?
#stm32cubemx #adc3 #stm32cubemx-4.25.1Solved! Go to Solution.
2018-05-28 2:21 AM
Hi
Vid.Max
,Thanks for your feedback.
This issue will be fixed in a next CubeMX release (4.1).
Regards,
Houda
2018-05-24 12:22 AM
line ADC3. in .ioc file
ADC3.Channel-0\#ChannelRegularConversion=ADC_CHANNEL_9
ADC3.Channel-205\#ChannelRegularConversion=ADC_CHANNEL_14ADC3.Channel-206\#ChannelInjectedConversion=ADC_CHANNEL_4ADC3.Channel-207\#ChannelInjectedConversion=ADC_CHANNEL_15ADC3.Channel-208\#ChannelInjectedConversion=ADC_CHANNEL_6ADC3.Channel-209\#ChannelInjectedConversion=ADC_CHANNEL_7ADC3.Channel-210\#ChannelRegularConversion=ADC_CHANNEL_4ADC3.Channel-IN14=ADC_CHANNEL_14ADC3.Channel-IN15=ADC_CHANNEL_15ADC3.Channel-IN4=ADC_CHANNEL_4ADC3.Channel-IN6=ADC_CHANNEL_6ADC3.Channel-IN7=ADC_CHANNEL_7ADC3.Channel-IN8=ADC_CHANNEL_8ADC3.Channel-IN9=ADC_CHANNEL_9ADC3.ClockPrescaler=ADC_CLOCK_SYNC_PCLK_DIV8ADC3.ContinuousConvMode=DISABLEADC3.DMAContinuousRequests=ENABLEADC3.DataAlign=ADC_DATAALIGN_RIGHTADC3.DiscontinuousConvMode=DISABLEADC3.EOCSelection=ADC_EOC_SEQ_CONVADC3.EnableAnalogWatchDog=falseADC3.ExternalTrigConv=ADC_SOFTWARE_STARTADC3.ExternalTrigConvEdge=ADC_EXTERNALTRIGCONVEDGE_NONEADC3.ExternalTrigInjecConv=ADC_INJECTED_SOFTWARE_STARTADC3.ExternalTrigInjecConvEdge=ADC_EXTERNALTRIGINJECCONVEDGE_NONEADC3.IPParameters=Channel-IN4,Channel-IN6,Channel-IN7,Channel-IN8,Channel-IN9,Channel-IN14,Channel-IN15,ClockPrescaler,Channel-205\#ChannelRegularConversion,master,NbrOfConversion,NbrOfConversionFlag,Channel-0\#ChannelRegularConversion,Resolution,DataAlign,ScanConvMode,ContinuousConvMode,DiscontinuousConvMode,DMAContinuousRequests,EOCSelection,ExternalTrigConv,ExternalTrigConvEdge,InjNumberOfConversion,EnableAnalogWatchDog,Rank-0\#ChannelRegularConversion,SamplingTime-0\#ChannelRegularConversion,Rank-205\#ChannelRegularConversion,SamplingTime-205\#ChannelRegularConversion,Rank-206\#ChannelInjectedConversion,Channel-206\#ChannelInjectedConversion,SamplingTime-206\#ChannelInjectedConversion,InjectedOffset-206\#ChannelInjectedConversion,Rank-207\#ChannelInjectedConversion,Channel-207\#ChannelInjectedConversion,SamplingTime-207\#ChannelInjectedConversion,InjectedOffset-207\#ChannelInjectedConversion,Rank-208\#ChannelInjectedConversion,Channel-208\#ChannelInjectedConversion,SamplingTime-208\#ChannelInjectedConversion,InjectedOffset-208\#ChannelInjectedConversion,Rank-209\#ChannelInjectedConversion,Channel-209\#ChannelInjectedConversion,SamplingTime-209\#ChannelInjectedConversion,InjectedOffset-209\#ChannelInjectedConversion,Rank-210\#ChannelRegularConversion,Channel-210\#ChannelRegularConversion,SamplingTime-210\#ChannelRegularConversion,ExternalTrigInjecConv,ExternalTrigInjecConvEdge,InjectedConvModeADC3.InjNumberOfConversion=4ADC3.InjectedConvMode=NoneADC3.InjectedOffset-206\#ChannelInjectedConversion=0ADC3.InjectedOffset-207\#ChannelInjectedConversion=0ADC3.InjectedOffset-208\#ChannelInjectedConversion=0ADC3.InjectedOffset-209\#ChannelInjectedConversion=0ADC3.NbrOfConversion=2ADC3.NbrOfConversionFlag=1ADC3.Rank-0\#ChannelRegularConversion=1ADC3.Rank-205\#ChannelRegularConversion=1ADC3.Rank-206\#ChannelInjectedConversion=1ADC3.Rank-207\#ChannelInjectedConversion=2ADC3.Rank-208\#ChannelInjectedConversion=3ADC3.Rank-209\#ChannelInjectedConversion=4ADC3.Rank-210\#ChannelRegularConversion=2ADC3.Resolution=ADC_RESOLUTION_12BADC3.SamplingTime-0\#ChannelRegularConversion=ADC_SAMPLETIME_480CYCLESADC3.SamplingTime-205\#ChannelRegularConversion=ADC_SAMPLETIME_480CYCLESADC3.SamplingTime-206\#ChannelInjectedConversion=ADC_SAMPLETIME_480CYCLESADC3.SamplingTime-207\#ChannelInjectedConversion=ADC_SAMPLETIME_480CYCLESADC3.SamplingTime-208\#ChannelInjectedConversion=ADC_SAMPLETIME_480CYCLESADC3.SamplingTime-209\#ChannelInjectedConversion=ADC_SAMPLETIME_480CYCLESADC3.SamplingTime-210\#ChannelRegularConversion=ADC_SAMPLETIME_3CYCLESADC3.ScanConvMode=ENABLEADC3.master=12018-05-24 12:42 AM
Hi
Vid.Max
Could you please precise the device you're using and if possible share your complete ioc file.
Khouloud.
2018-05-24 3:05 AM
2018-05-24 4:39 AM
Hello
Vid.Max
,This forwarded to our CubeMX team. One of our experts will answer you ASAP.
Khouloud.
2018-05-28 2:21 AM
Hi
Vid.Max
Regards,
Houda
