2023-07-18 4:58 AM
I am using the STMicroelectronics.X-CUBE-AI.8.0.1 with the board STM32U5A5ZJTxQ
Here is what I did:
Question: at the network place: is it possible to add two datasets, so two files, in the inputs into the validation inputs section or/and in the validation outputs? If yes, is it possible to do it for several datasets?
Thank you in advance,
2023-07-26 8:44 AM
Hello @MMary.11
First of all, I want to thank you for reporting.
STMicroelectronics X-CUBE-AI focused on converting and optimizing the pre-trained neural network models.
The training process is done by using external deep learning frameworks like TensorFlow or PyTorch on the Host Machine.
The validation process is a part of the training stage, and it is performed outside STM32Cube AI. That's why you can use many validation datasets depending on the complexity of your model and the size of your datasets.
I advise you to refer to the official documentation and resources provided by STMicroelectronics.
AI:X-CUBE-AI documentation - stm32mcu
2023-07-26 8:44 AM
Hello @MMary.11
