2020-03-14 5:04 AM
2020-03-14 7:42 AM
If the sensor is at rest, acceleration is earth gravity vector and the accelerometer xyz readings can be transformed into Euler angles quaternions, etc..
If the sensor is moving, you might need to add some filtering and gyro readings. There is a nice series of tutorials explaining that: http://www.brokking.net/imu.html
2020-03-14 7:44 AM
thank you for your reply
