2019-11-18 5:09 PM
In the release notes, it says the latest compatible Cube FW is 1.24.0. But Cube FW 1.24.1 is listed at a patch. So which should I install with STM32CubeMX 5.1.0?
When I start STM32CubeMX in its perspective I get a popup with the message "This release of STM32CubeMX Eclipse Plugin cannot be used in macOS". Is this true? What release should I use on a Mac? If I click OK on the popup, everything appears to work. Does it? Can I ignore this popup?
