2018-12-10 7:38 AM
I was searching for smaller and cheaper MCU with CAN network. I have chosen the STM32F042F4P6 trough CubeMX but now when I try to enable CAN in CubeMX I cannot because it's grayed. What am I doing wrong?
2018-12-10 8:40 AM
I found it.
You need to swap the pins under SYS: "Pins PA11/12 instead of pins PA9/10"
Answer is also in question below
2018-12-10 8:40 AM
I found it.
