2020-02-12 5:19 AM
I'm working on NUCLEO-H743ZI board, using the STM32CubeMX 5.4.0 tool.
When i'm generating code for SPI using DMA - It seems that it doesn't work.
I tried to generate the same code for another device (STM32F411 Discovery Board) and i sow that there is a difference between this two components in the initialization order:
STM32F411
MX_DMA_Init();
MX_SPI1_Init();
NUCLEO-H743ZI
MX_SPI1_Init();
MX_DMA_Init();
When I switched between these two functions it seems that the problem solved.
is it a bug in the IDE?
2020-02-12 11:56 AM
This is a problem with the older version of STM32CubeMX, but I believe it's been solved recently with a patch. In the older version, you can also solve the problem by manually changing initialization order as described, e.g., in the comments here:
https://community.st.com/s/question/0D50X0000BvjWnfSQE/bug-in-cubemx-code-generation-for-spidma
Michael
2020-02-12 11:56 AM
Michael
2020-02-12 11:01 PM
Thanks a lot Michael!
I manually changed the initialization order as described in link...
