2019-01-25 12:12 PM
I generated a simple project to create a base for a project including a web server on STM32F429 Nucleo board.
The CubeMX-generated code fails to build.
This morning, within CubeMX plug-in I downloaded and installed the latest pack and CubeMX, but the Help->About still says version 5.0.0 STMCube v1.0. What version am I actually running?
I've attached the IOC so you can easily generate code and reproduce the problem.
Please let me know how to get a working example!
Thanks, Best Regards, Dave
2019-01-28 5:36 AM
What is exactly the failure seen ?
I tried to generate your code and I have this error: "fatal error: fsdata.c: No such file or directory".
"What version am I actually running?" => You are using CubeMx version 5.0.0 and not the latest version V5.0.1.
Kind Regards,
Imen
2019-01-28 6:08 AM
@Imen DAHMEN -First, if you deal with the fsdata.c problem, you will find many other errors. If you fix them all, the code does not even work. Is a developer who is familiar with lwip and cube working on repairing this?
Second: You are telling me that the CubeMX plug-in's update process does not work?
How can I get it to work?
CubeMX plug-in currently says all updates are applied (to both cube and the library/pack), so either:
What's going on?
Thanks,
Best Regards, Dave
2019-01-28 7:23 AM
Hi @Dave Nadler ,
I raised internally to CubeMX team your issue regaring CubeMX plug-in for check.
Also, the Lwip+FreeRTOS issue is under investigation and we will come back to you soon with update.
Kind Regards,
Imen
2019-01-28 7:31 AM
@Imen DAHMEN - CubeMX update failure, or web server example failure?
Are both problems under investigation?
Thanks!
Best Regards, Dave
2019-01-28 7:34 AM
@Dave Nadler , Both problems are under investigation.
Kind Regards,
Imen
2019-01-29 6:20 AM
Your request has been forwarded for the development of the team. it will be fixed in the next version CubeMX.
Best Regards,
Wael
2019-01-29 6:52 AM
@WBOUG - CubeMX update failure, or web server example failure?
Will both problems be fixed in next release?
Thanks!
Best Regards, Dave
