2025-06-18 2:24 AM
When using USART2 on the C071, CubeMX is generating calls to functions like `HAL_UARTEx_SetTxFifoThreshold` but the USART2 on C071 is a basic UART without FIFO.
2025-06-18 3:39 AM
Hello @G565
Your contribution is much appreciated.
Issue has been raised to development team for fix.
Internal ticket number: 212488
I will keep you posted with updates.
THX
Ghofrane
2025-06-18 2:47 AM
Hello @G5658
I'm currently investigating this issue issue .
I 'will get back to you asap.
THX
Ghofrane
2025-06-18 3:39 AM
Hello @G565
THX
Ghofrane
2025-09-26 5:35 AM
Hi, is there an estimate for when this might be fixed? 6.15 was released in July and still had the problem.
Is there a workaround other than hacking the generated code? Maybe using ll_ instead of HAL? The ll_ code doesn't have the check and just writes to the CR3 register bits, even though it has no effect.
Regards,
Mike
