  • 1756 Views
STM32CubeMX, empty Clock Configuration tab
Posted on August 07, 2014 at 22:42STM32CubeMX ver.4.3.0 / STM32Cube V1.0Generated the attached STM32CubeMX project file.Upon reloading the project the Clock Configuration tab is empty - it does not show the clock tree info.What should I do to fix th...
adrian2 by Associate
  • 1525 Views
Am I right for configure the UART?
Posted on July 06, 2014 at 15:59 Hi guys, I tried to make a project by STM32CubeMX. I configured the MCU and the Project file is this (USART.ioc) : #MicroXplorer Configuration settings - do not modify #Sun Jul 06 17:52:14 IRDT 201...
STM32CubeMx Offline Update with new FW Libraries
Posted on August 05, 2014 at 17:42Hello, it is nearly impossible to update the Firmware Libraries for the CubeMx Tool on a PC without Internet connection, following the description in the manual. Please clearify the the procedure. Probably there is ...
STM32CubeMX clock config bugs
Posted on April 08, 2014 at 17:20I have two probably-related bugs relating to clock configuration in the pinout and clock configuration wizards of the STM32CubeF4 tool; I have been unable to find any references to these bugs, so I don't know if ther...
Steve H by Associate III
  • 7369 Views
STM32CubeMX Project files for STM324xG-EVAL
Posted on March 06, 2014 at 13:02Hi,It would be great to have access to the STM32CubeMX project files for various evaluation and demonstration boards, like the STM324xG-EVAL that uses the STM32F407IGH6 processor. This would greatly help porting a de...
nicholas by Associate II
  • 3950 Views
STM32CubeMX doesn't ship CMSIS math/DSP libs
Posted on June 03, 2014 at 19:15Hi, I've been trying to use some of the math/DSP functions from CMSIS, but that doesn't seem to work out of the box since STM32CubeMX doesn't generate/copy the required library files. It does, however, copy (some vers...
u_ by Associate
  • 1317 Views
Bug in HAL_Delay() all Cube SDK
Posted on May 13, 2014 at 07:23 Hi! I'm sure there is a bug inHAL_Delay() when current time returned by HAL_GetTickis close to overflow (0xFFFFFFFF). Check out this code: http://ideone.com/MAdwBN Second version ofHAL_...
ryabinin by Associate
  • 1508 Views
