  • 1757 Views
STM32 L476RG: DMA + SDMMC: SDMMC Timeout after Write
Posted on September 04, 2017 at 12:58I'm trying to get the DMA + SDMMC to write to an SD Card using the HAL_SD_WriteBlocks_DMA() function. After I call the function, the HAL_DMA_GetState() function never returns HAL_DMA_STATE_READY, and the same is ...
How to correctly synchronize timer with ADC
Hello everyone,I have problem with my univeristy project and I'm trying to find some help.I'm using Nucleo64 STM32F411RE.The most important setting in CubeMX:In ADC every rank have 3 cycles, and Rank 1-4 Channel 10, Rank 5-8 Channel 11, Rank 9-12 Cha...
STM32F103R8Tx with STM32CubeMX Hal malfunction with i2c
I'm using 24C512 EEPROM with my STM32F1, i initialized the project with stm32cubemx and defined my SCL and SDA pins as I2C, when i try isDeviceReady function i never get HAL_OK.I've also grounded A0,A1,A2,Wp of the eepromMy Codeint main(void) { /* ...
JRuda by Associate
  • 915 Views
Resolved! Archive for STM32CubeMX versions
I need to re-install STM32 CubeMX 4.19 as the latest version 4.24 is not compatible with my existing code base. I inadvertently migrated to 4.24 but need to return to 4.19. Where can I find an archive installer for the older version?
How to install CubeMX with Docker
Hello all.I would like to install the STM32CubeMX using Docker file for Ubuntu. How shall I do this?I know how to use the X-server, and GUI under docker with Ubuntu, however, when downloading the STM32Cube one has to register. I would like to automat...
