  • 1757 Views
Compile with Makefile on Ubuntu 18.04 LTS
Hi,I am trying to compile a generated Makefile project on an Ubuntu machine (18.04 LTS). The compilation works fine on Windows 10.But on Ubuntu, I get the following error:kai@ubuntu:~/workspace/makefile_test$ make arm-none-eabi-gcc build/main.o build...
smrtkai by Senior
  • 3941 Views
CubeMX has tiny text on HiDPI screens
All text in the CubeMX standalone application is really small when viewed on a HiDPI screen. Some symbols and controls are also too small.Please make sure that text and symbol size adapts to the screen resolution.
How to set up CubeMX for USB HS CDC (VCP) on STM32F746 Discovery?
Hello,After succeeded to run CDC device on FS port, I'm trying to get HS port working in HS mode, as I'm interested in lower latency. But cannot find any simple guide to set it up in Cube. Trying to enable USB_OTG_HS (External Phy = Device_Only), it ...
Wowa by Associate III
  • 933 Views
USART1 initialization problem
Hello,I use stm32f303 discovery board and try to enable usart 1 as described in ..stm32cuvef3/projects/STM32303C_EVAL/uart/hyperterminalDma example. When I set USART1 and it's relative pin and ports I see the output as expected but I am not able to ...
swer by Associate II
  • 2090 Views
How can i set CubeMX to get ADC data in stm32f103rb?
Hi. I'm KAI. I want to configure the system to receive the sensing value by ADC.The system configuration I am currently thinking is as follows.The system is the same as the attached file. In STM32F103RB, the serial data and the SR clock signal are in...
kkiha by Associate
  • 1230 Views
Latest Version of STM32CubeMX
PLEASE PLEASE PLEASE Ditch STM32CubeMX version 5.This is the Worst software I have ever has the misfortune to use.Previous versions were bad but I would happily go back now I see how bad V5 is.AndyP.S. Your forum software is only marginally better th...
