2019-01-11 9:05 PM
Can anyone help me?
Here is the log:
chdir /home/cxcygzf/STM32CubeMX/.
current dir /home/cxcygzf/STM32CubeMX
log4j user configuration file not found: /home/cxcygzf/.stm32cubemx/log4j.properties
Configure log4j with default settings from jar:file:/home/cxcygzf/STM32CubeMX/STM32CubeMX!/log4j/log4j.stm32cubemx.properties
2019-01-12 12:58:09,972 [INFO] MicroXplorer:486 - Detected Java Version = 1.8.0_192
2019-01-12 12:58:09,979 [INFO] ApplicationProperties:181 - Using Application install path: /home/cxcygzf/STM32CubeMX
2019-01-12 12:58:09,999 [INFO] DbMcusXml:68 - Set database path to: /home/cxcygzf/STM32CubeMX//db//mcu/
2019-01-12 12:58:10,013 [INFO] DbBoardsPdsc:54 - Set plugin database path to: /home/cxcygzf/STM32CubeMX//db//plugins/boardmanager/
2019-01-12 12:58:10,014 [INFO] DbMcus:262 - Set plugin images path to: /home/cxcygzf/STM32CubeMX//db//plugins/mcufinder/images/
2019-01-12 12:58:10,014 [INFO] DbBoards:224 - Set plugin images path to: /home/cxcygzf/STM32CubeMX//db//plugins/mcufinder/images/
2019-01-12 12:58:10,017 [INFO] APIGFXSelector:72 - Set database path to: /home/cxcygzf/STM32CubeMX//db//plugins/mcufinder/mcu/
2019-01-12 12:58:10,022 [INFO] DbMcusAds:72 - Set database path to: /home/cxcygzf/.stmcufinder/plugins/mcufinder//mcu/
2019-01-12 12:58:10,023 [INFO] DbMcusDocs:90 - Set database path to: /home/cxcygzf/.stmcufinder/plugins/mcufinder//mcu/
2019-01-12 12:58:10,025 [INFO] DbMcusJson:58 - Set database path to: /home/cxcygzf/.stmcufinder/plugins/mcufinder//mcu/
2019-01-12 12:58:10,026 [INFO] DbBoardsDocs:82 - Set database path to: /home/cxcygzf/.stmcufinder/plugins/mcufinder//mcu/
2019-01-12 12:58:10,028 [INFO] DbBoardsJson:51 - Set database path to: /home/cxcygzf/.stmcufinder/plugins/mcufinder//mcu/
2019-01-12 12:58:10,552 [INFO] CrossReferenceDbSqlite:197 - Set database path to: /home/cxcygzf/.stmcufinder/plugins/mcufinder//mcu/
2019-01-12 12:58:10,792 [INFO] RulesReader:53 - Compatibility file has been processed (127 Rules)
2019-01-12 12:58:10,829 [INFO] STM32CubeMX:31 - Starting STM32CubeMX
2019-01-12 12:58:11,191 [INFO] MainPanel:139 - HeapMemory: 62390272
2019-01-12 12:58:11,420 [INFO] DbMcusXml:68 - Set database path to: /home/cxcygzf/STM32CubeMX//db//mcu/
2019-01-12 12:58:11,421 [INFO] DbBoardsPdsc:54 - Set plugin database path to: /home/cxcygzf/STM32CubeMX//db//plugins/boardmanager/
2019-01-12 12:58:11,422 [INFO] DbMcus:262 - Set plugin images path to: /home/cxcygzf/STM32CubeMX//db//plugins/mcufinder/images/
2019-01-12 12:58:11,430 [INFO] DbBoards:224 - Set plugin images path to: /home/cxcygzf/STM32CubeMX//db//plugins/mcufinder/images/
2019-01-12 12:58:11,431 [INFO] APIGFXSelector:72 - Set database path to: /home/cxcygzf/STM32CubeMX//db//plugins/mcufinder/mcu/
2019-01-12 12:58:11,431 [WARN] DbFile:31 - Overriding database path with different value: /home/cxcygzf/.stmcufinder/plugins/mcufinder/ => /home/cxcygzf/.stmcufinder/plugins/mcufinder
2019-01-12 12:58:11,432 [INFO] DbMcusAds:72 - Set database path to: /home/cxcygzf/.stmcufinder/plugins/mcufinder//mcu/
2019-01-12 12:58:11,432 [WARN] DbFile:31 - Overriding database path with different value: /home/cxcygzf/.stmcufinder/plugins/mcufinder/ => /home/cxcygzf/.stmcufinder/plugins/mcufinder
2019-01-12 12:58:11,432 [INFO] DbMcusDocs:90 - Set database path to: /home/cxcygzf/.stmcufinder/plugins/mcufinder//mcu/
2019-01-12 12:58:11,432 [INFO] DbMcusJson:58 - Set database path to: /home/cxcygzf/.stmcufinder/plugins/mcufinder//mcu/
2019-01-12 12:58:11,433 [WARN] DbFile:31 - Overriding database path with different value: /home/cxcygzf/.stmcufinder/plugins/mcufinder/ => /home/cxcygzf/.stmcufinder/plugins/mcufinder
2019-01-12 12:58:11,433 [INFO] DbBoardsDocs:82 - Set database path to: /home/cxcygzf/.stmcufinder/plugins/mcufinder//mcu/
2019-01-12 12:58:11,433 [INFO] DbBoardsJson:51 - Set database path to: /home/cxcygzf/.stmcufinder/plugins/mcufinder//mcu/
2019-01-12 12:58:11,437 [WARN] DbFile:31 - Overriding database path with different value: /home/cxcygzf/.stmcufinder/plugins/mcufinder/ => /home/cxcygzf/.stmcufinder/plugins/mcufinder
2019-01-12 12:58:11,437 [INFO] CrossReferenceDbSqlite:197 - Set database path to: /home/cxcygzf/.stmcufinder/plugins/mcufinder//mcu/
2019-01-12 12:58:11,466 [INFO] ApplicationProperties:181 - Using Application install path: /home/cxcygzf/STM32CubeMX
2019-01-12 12:58:11,468 [INFO] PluginManage:167 - Search for loadable plugins [exclusion list=]
2019-01-12 12:58:11,472 [INFO] PluginManage:289 - Check plugin thirdparty
2019-01-12 12:58:11,508 [INFO] ThirdPartyDb:293 - Open Third Party DataBase File (/home/cxcygzf/.stm32cubemx/plugins/thirdparty/db/thirdparties_db.xml) : 1 ms. number of Sw pack : 0
2019-01-12 12:58:11,528 [INFO] PluginManage:339 - Loaded plugin thirdparty (category:base,tabindex:-1)
2019-01-12 12:58:11,529 [INFO] PluginManage:289 - Check plugin projectmanager
2019-01-12 12:58:11,660 [INFO] PluginManage:339 - Loaded plugin projectmanager (category:projectmanager,tabindex:3)
2019-01-12 12:58:11,661 [INFO] PluginManage:289 - Check plugin updater
2019-01-12 12:58:11,675 [INFO] PluginManage:339 - Loaded plugin updater (category:base,tabindex:12)
2019-01-12 12:58:11,676 [INFO] PluginManage:289 - Check plugin tools
2019-01-12 12:58:11,678 [INFO] PluginManage:339 - Loaded plugin tools (category:base,tabindex:5)
2019-01-12 12:58:11,678 [INFO] PluginManage:289 - Check plugin power
2019-01-12 12:58:11,718 [INFO] PluginManage:339 - Loaded plugin power (category:power,tabindex:4)
2019-01-12 12:58:11,721 [INFO] PluginManage:289 - Check plugin clock
2019-01-12 12:58:11,738 [INFO] PluginManage:339 - Loaded plugin clock (category:base,tabindex:2)
2019-01-12 12:58:11,739 [INFO] PluginManage:289 - Check plugin ipmanager
2019-01-12 12:58:11,756 [INFO] PluginManage:339 - Loaded plugin ipmanager (category:base,tabindex:5)
2019-01-12 12:58:11,756 [INFO] PluginManage:289 - Check plugin pinoutandconfiguration
2019-01-12 12:58:11,768 [INFO] PluginManage:339 - Loaded plugin pinoutandconfiguration (category:base,tabindex:1)
2019-01-12 12:58:11,768 [INFO] PluginManage:289 - Check plugin analytics
2019-01-12 12:58:12,144 [INFO] UserProfileFactory:23 - /com/st/library/analyticscore
2019-01-12 12:58:13,096 [INFO] UserProfileFactory:25 - b3833c12_4463_4078_9ef0_00b6bb528df7
2019-01-12 12:58:13,111 [INFO] AnalyticsPlugin:190 - Accepted Software Licenses: STM32CubeMX.5.0.1
2019-01-12 12:58:13,112 [INFO] AnalyticsPlugin:192 - Accepted CMSIS Pack Licenses:
2019-01-12 12:58:13,112 [INFO] AnalyticsPlugin:194 - Accepted Firmware Licenses:
2019-01-12 12:58:13,112 [INFO] PluginManage:339 - Loaded plugin analytics (category:tool,tabindex:-1)
2019-01-12 12:58:13,113 [INFO] PluginManage:289 - Check plugin filemanager
2019-01-12 12:58:13,213 [INFO] PluginManage:339 - Loaded plugin filemanager (category:base,tabindex:10)
2019-01-12 12:58:13,217 [INFO] PluginManage:289 - Check plugin pinoutconfig
2019-01-12 12:58:13,234 [INFO] PluginManage:339 - Loaded plugin pinoutconfig (category:base,tabindex:0)
2019-01-12 12:58:56,528 [ERROR] IntegrityCheckThread:90 - Cannot obtain updater plugin
2019-01-12 12:58:56,529 [INFO] IntegrityCheckThread:94 - End integrity checks thread
2019-01-12 12:58:56,529 [INFO] ThirdPartyDb:263 - Close Third Party DataBase File (/home/cxcygzf/.stm32cubemx/plugins/thirdparty/db/thirdparties_db.xml)
