2019-11-21 2:38 AM
I am currently using NUCLEO-LPM01A to measure current consumption.
Is it possible to change default settings when starting the board?
For exemple, I would like to change parameter integration time from default value 1 to 100s.
In this case, without computer, manipulation would be easier for technician to see more precise current average than for 1s.
Si this would be to:
Measure current consumption with external board without computer.
Thanks
David
2019-11-28 8:15 AM
Hi David,
Unfortunately, it is not possible to change default settings at board power-up.
Best regards
Philippe
2019-11-28 8:15 AM
Hi David,
Best regards
Philippe
