2020-04-14 3:28 AM
i installed the ide and used it for 2 or 3 program. it was working fine. programming was OK. debug was OK.
but after a while the MCU was always falling into hardfault.
after 10 times of programming and changing the code it was stock in wierd lines of code. i couldn't even imagine the reason. at first i thought it is the code problem but i open the exact same project with cubeMX in keil and the code was working OK!!!!
what is happing here???
2020-04-14 8:11 AM
Hi @Community member
Could you please share your project.
Which CubeIDE version do you use ?
Reagrds,
Nesrine
