2020-04-12 5:37 AM
I got with the CUBE IDE the following problem, at some random point in the program, the Debugger halts and throws the following error:
handle_vCont_t, Thread already stopped
It occurs several times a weak and I didn't found a solution to this
2021-03-19 6:06 AM
Hi Aish,
I'm experiencing the very same problem and can't find a cause. Since some time has passed, I'm wondering if you have found a solution or some mitigation. Thank you.
