2019-12-21 1:55 AM
I am having problems using SWV options with c++ projects, using a Nucleo F767ZI board.
I tried using SWV data trace with a simple C project and everything works fine, however (using the same configuration I used in the C project) I couldn't get any output on any SWV perspective.
Did anyone manage to make swv work with C++ projects?
2025-04-06 11:13 PM
hello, I'm also having the same issue. Did you find a fix for this ?
