2024-09-21 5:50 AM
Hi, I'm trying to upload a blank code generated by the ioc file on STM32H7S3L8 and I'm getting this error: "Break at address "0x800efb8" with no debug information available, or outside of program code." How can this error be fixed?
2024-09-21 7:21 AM
This error typically occurs when the debugger encounters a memory address that doesn't contain valid program code or debug information. Check if your debug configuration in your IDE (like STM32CubeIDE or Keil) is set correctly. Sometimes, the issue is caused by the debugger attempting to break at an invalid location.
