2024-01-14 12:48 AM
Hi Gents,
Something weird is going on my computer since a long while, but it gets very annoying as I work with more on this computer. If I open a .ioc file, or do anything in STM32CubeIDE that will bring up a non-eclypse dialog, the GUI misbehaves in a very weird way. Best example is if I go to Software Packs -> Select Components menu - it becames absolutely unusable, every time I open it up. I attached a file where you can see, how the window looks like after scrolling the list or open up a dropdown item.
This happens, when e.g.
This doesn't happens when e.g.
Note, that eclypse dialogs, even if contain "ST elements" like drop-downs, text fields, etc, does not produce this error. If a dialog is fully ST based, this happens.
Also, I tried the followings:
Further notes:
Apparently it has something to do with the graphics card / driver, but I have no idea anymore, how to go further. I use STM32CubeIDE on 3 other computers with no issue.
The configuration I use:
Thank you for your support!
2024-01-14 1:30 AM - edited 2024-01-14 2:02 AM
"The puzzled windows problem" is not really "new" , but afaik until now no solution by STM .
see:
https://community.st.com/t5/stm32cubemx-mcus/cubemx-ui-is-messed-up-again-again-and-again/m-p/580741
https://community.st.com/t5/stm32cubemx-mcus/cubemx-interface-bug/m-p/591221#M26001
...and many more .
Sometimes seems to help, if graphics text or icon size is changed; or using only one screen, if two been used.
see:
...and many more .
2024-01-14 2:13 AM
bad news. I tried to play with text and graphics size, but it just get worse.
Anyway, thank you for your support!
