2024-10-28 10:13 AM - last edited on 2024-10-28 10:24 AM by Andrew Neil
Hello All,
I am using Ubuntu 24.04 and STM32 Cube IDE 1.16 version. When I try to burn code to a STM32F401RE Nucleo board. I am getting below error.
Could not determine GDB version using command: arm-none-eabi-gdb --version
arm-none-eabi-gdb: error while loading shared libraries: libncurses.so.5: cannot open shared object file: No such file or directory
and yes I have tried sudo get-install.
Does STM team has any suggestion ?
Thank you
2024-10-28 10:22 AM - edited 2024-10-28 10:25 AM
https://community.st.com/t5/stm32cubeide-mcus/i-can-t-install-ide-cube-on-ubuntu-24/m-p/725849
2024-10-28 9:43 PM - edited 2024-10-28 9:44 PM
Hello ,
ST should write this at download page!! That Ubuntu 24.04 is not supported.
Is there any alternatives to use STM Controllers in 24.04 or changing the Os the only option?
Thank you,
