2020-04-01 3:17 AM
Hi, using STM32CubeIDE 1.3.0 and the last libraries for H7 and FREERTOS, I have found a very big issue, when you edit the name of one existing TASK and you generate source code again, the new project is a working project, but has many parts of code removed or not completed, so the resulting compiled code is not working anymore. Using a WinMerge utility to diff files show me many source code is wrong generated! Can someone of ST investigate the issue?
Has someone the same user experience?
Best regards
2020-04-01 3:23 AM
Also deleting an empty TASK will corrupts the source code!
2020-04-01 5:43 AM
2020-04-02 9:06 AM
