2023-10-23 3:06 PM - edited 2023-10-23 3:08 PM
I installed STM32CubeIDE 1.13.2 in the hope that the problem of the 1.13.1 release has been solved (see My old topic ) . Nothing the problem continues to exist. To make the integrated CubeMX work I have to open and close the IDE 3 or 4 times, also if it doesn't start I have to delete the home/user/workspace_1.13.2/.metadata directory. (for my system config see My old topic )
Thanks for your help.
Ferdinando
2023-10-31 1:44 AM
Hello @Fendo59
This issue is reported internally (Internal ticket number:165338) .
I will keep you posted with updates.
Thx
Ghofrane
2023-10-27 7:34 AM
Hello @Fendo59
First let me thank you for posting .
Could you please provide the log that is located in home/user/workspace_1.13.2/.metadata directory. I need to check it to know about what might be causing the problem .
I will be waiting for your feedback.
Thx
Ghofrane
2023-10-27 8:19 AM
2023-10-27 9:39 AM
2023-10-30 8:00 AM
Hello @Fendo59
Could you please provide your Ubuntu version.
Use the lsb_release -a command to display the Ubuntu version.
Thx
Ghofrane
2023-10-30 8:26 AM
HI @Ghofrane GSOURI
here is my release: fendo@HP-250-G5:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 22.04.3 LTS
Release: 22.04
Codename: jammy
Note that the 1.12.0 release always works if every time I delete the "home/user/STM32CubeIDE/workspace_1.12.0/.matadata/.plugins/org.eclipse.e4.workbench" folder.
Thanks
Ferdinando
2023-10-31 1:44 AM
Hello @Fendo59
Thx
Ghofrane
2023-10-31 5:13 AM
Hello @GSOURI
Thank you very much.
Fendo59
2023-11-07 7:19 AM
Here you can find the required files
2023-12-18 2:42 AM
News!
I installed version 1.14.0, it worked fine 6 times, then it started showing the same problems. Since then it has gotten worse to the point that I have to delete the usual 4 folders, like for the previous release.
Good morning
