2025-08-29 12:29 AM
Hey all.
As per tradition, my first post in this community will be a question.
In the same way that I can run pre- and post-build commands that is run when I build a project in STM32cube, is it possible to run a post code generation command when I generate code from the .ioc file?
- Moose
2025-08-29 12:56 AM
Hello @Moose
Welcome to ST Community
In STM32CubeMX and STM32CubeIDE, you will find fields labeled:
"User action, Before code generation"
"User action, After code generation"
These fields allow you to specify commands or scripts that will be executed:
Before code generation:
The command in the "Before code generation" field runs just before the code is generated from the .ioc file.
After code generation:
The command in the "After code generation" field runs immediately after the code is generated.
THX
Ghofrane
2025-08-29 12:56 AM
Hello @Moose
THX
Ghofrane
2025-08-29 12:59 AM
Glorious!
Exactly what I was looking for. Had missed the tabs in that view.
Many thanks! :)
- Moose
