2025-04-08 5:00 AM - last edited on 2025-04-08 5:31 AM by Andrew Neil
Hello everyone !
I try to open my ioc file in stm32IDE but I have this message and can't open also open in stm32CubeMx.
I use stm32G431RB and FW_G4 V1.6.0
Someone to help me please?
2025-04-08 6:02 AM
In addition, you are welcome to upload the IOC here and we will be happy to check it for consistency and completeness - it may have been damaged beforehand.
2025-04-08 5:36 AM
Welcome to the forum.
Please see How to write your question to maximize your chances to find a solution for best results.
@mala wrote:I try to open my ioc file in stm32IDE
How, exactly, did you try to open it?
What CubeIDE & CubeMX versions are you using?
What is your Host platform?
The message says that the problem is probably due to an "abnormal previous IDE session exit" - is that the case?
If so, did you try closing everything and restarting the computer?
2025-04-08 6:02 AM
2025-04-08 9:01 AM
I change the file. But now, I have anathor question. The file I use is one of the example on stm32G431RB "DAC_SignalGeneration2" and for this example, the output frequency on Oscillo is 1kHz but for my use, I want to have high frequency for sinusoidal signal on oscilloscope. I try many issu but i don't have what i want.
For example, I calculated PSC et ARR corresponding to my frequency i want or double the number of step in tab sinewave or do (programmed a specific tab sinwave at the frequency i want but i stil don't have good result on oscilloscope.
And i don't understand the specific roles of each timer (TIM2 & TIM6) in this code.
Thank you for you respond
2025-04-08 9:07 AM - edited 2025-04-08 9:07 AM
@mala wrote:But now, I have another question.
Please keep to just one question per thread.
I've moved the other copy of that reply to a new thread:
continue the discussion there...
