2023-07-10 1:58 AM
I'm pretty sure that this is not implemented yet, but it would be extremely helpful to do so. I want to write the variables through the live expressions tab in the debugging mode, like I'm used to do in the IAR EW.
If this option is already available and functioning let me know.
2023-07-11 9:46 AM
Hello @TKleg.2
If I well understood your request, you want to change the value of the variables through the "Live Expression"?
If this is the case, I am afraid to inform you that such feature is not supported at the moment; maybe in the future.
KR,
Semer.
2023-07-10 2:16 AM
A workaround of this "issue" is to look at the address, in the live expressions (from v.1.12.0), where the variable is saved and then change it in the memory tab.
2023-07-11 9:46 AM
Hello @TKleg.2
KR,
Semer.
