2019-07-12 3:08 AM
Our company intends to change the development tool from Keil to CubeIDE, but we have a lot of old projects based on Keil. Is there any way to import Keil project into CubeIDE?
2019-07-12 4:04 AM
Hi, I belief not implemented yet. Use Attolic True Studio to import Keil, get it to compile and run and then import True Studio project into STM32CubeIDE. That's the difference between paying $5000/seat and $0. I hope this helps.
2019-07-12 9:56 AM
Hi, yeah @hansd56 is saying correct you should try importing through the same procedure. I have tried importing projects from True Studio it just asks for some changes which you need or not it's going to make changes for you on its own.
Siingla
2019-07-12 10:26 AM
I think i'd wait for 3.0 to arrive before steering a commercial project off the rails.. At least factor in the man/month costs of time you'll be wasting dealing with all the QA issues.
If you are using ST CM0(+) chips there is a free Keil license.
Keil MDK Essential is around $1500/node/year
Keil uses XML project files, I'd imagine a marginally competent CS/EE intern could write a script to morph most of that to a buildable project in some other tool or makefile.
2019-07-13 1:58 PM
2020-04-15 3:11 PM
Is there any updates on this?
I am trying to port over from Keil to STM32CubeIDE now
2021-02-19 10:10 AM
Me too. Still waiting. How did DamogranLabs go?
