IDE hangs (freezes) after collapsing ( minimizing window) and expanding (maximizing). Linux
VK.17
Associate II
IDE hangs after collapsing ( minimizing window) and expanding (maximizing). Or after Alt + Tab. From time to time.
"File -> Restart" only helps.
I don't know how to fix this. Please, help.
Tried to reinstall - the same situation.
IDE uses internal Java: java.version=17.0.11
As system Java versions, I have v.18, 21, 22  (checked via "update-alternatives --config java" command)
Just have an idea to try to switch from internal to system version of Java, but did not find how it can be done.
My config:
Laptop Dell Vostro 3520
Ubuntu 22.04.4
4 REPLIES 4
VK.17
Associate II
Maybe this will help (see attachment)
Souhaib MAZHOUD
Hello @VK.17
Have you tried the CubeIDE 1.16.1 version? Can you check if the behavior still occurred?
KR,
Souhaib
Yes, the same behavior.
VSousa
Associate
I'm using the version 2.0.0 and the same behavior. The problem persists.
Arch Linux, fully updated, using Wayland.
