2021-09-15 5:31 AM
2021-09-15 5:34 AM
Hello there!
SWV tracing does not work with Cortex-M0, that is why the button to enable SWV is greyed out.
You could try to use Live Expressions if you want to check a specific variable for example. If you specifically need SWV then you would need to use another board.
2021-09-15 5:34 AM
Hello there!
2021-09-17 12:38 AM
Thanks Markus,
I've used the following tutorial on live expressions :
https://www.youtube.com/watch?v=Nyml66k_Ppk&ab_channel=RADAS
This works fine.
