2022-08-18 12:56 PM
2022-08-19 12:37 AM
Unfortunately, you did not mention which tool you use, which files you get from where, which problems you have when trying to add them, etc. Currently not easy to give an answer.
Is it possible for you to provide a few more details for evaluation?
/Peter
2022-08-19 1:19 AM
CubeIDE was indicated
2022-08-19 1:42 AM
Correct, thank you for pointing this out, I did indeed overlook it and have already corrected it in my query.
2022-08-19 9:04 AM
2022-08-19 9:56 AM
Yeah, that's probably because it wants to auto-generate, and you've added a lot of you own clutter. I'm not a CubeMX/IDE adherent, so I don't claim to be an expert, but have seen people lose significant amounts of work trying make two conflicting paradigms function.
Might I suggest sandboxing the auto-generated stuff, and other pieces you want to combine, and then make an actual free standing project that you then merge into with the sub/super-set of what you really want in the final project. As an exercise it also lets you see what and how things change as you modify an IOC file, and where different things live.
