How works "Enable RTOS proxy"?How to use it?Thank you.
IVent.1
Senior
3 REPLIES 3
KDJEM.1
Hello @IVent.1​,
This post explains well how to enable the RTOS proxy. For that, I advise you to take a look at it.
You can enable the RTOS proxy in the debug config, for example, if you need to examine the stack of all existing threads in the RTOS (inspecting local variables etc).
When your question is answered, please close this topic by choosing Select as Best. This will help other users find that answer faster.
Kaouthar
IVent.1
Senior
Thank you, I know how to enable it, but how to use it? I mean, I have enabled it but I don't see any difference...how can I see the effects of this enabling?Thank you, Isabella
KDJEM.1
Hi @IVent.1​,
Thank you for this explanation.
Enabling the proxy should give you the call stack of each thread in the "Debug" view (for FreeRTOS or ThreadX).
->how to use it?
I recommend you this video also you can take a look at the UM2609 and precisely section 6.3
I hope this helps!
Kaouthar
